i have a 16' mistral and it's a open cockpit design. now i plan on having a outboard on the boat. what equipment should i keep on board. i know pdfs for every one but what else. the reason i ask this because of the limited space to put stuff.
It still really depends on where you are and what the rules are. Beyond being legal, on a boat this size (assuming on a lake?), a few tools to make simple repairs is about all you need. Anything else would be determined on each outings needs more than boat needs.
Where are you sailing? IMHO, for dingy day sailing, something to bail with, a paddle if you want (you can also rock the boat side to side to propel yourself forward), pfds (a dingy vest), something to drink, something to eat.... that's about it. And of course venue appropriate clothing. That's related to the 'where' question. Extra? A handheld VHF for weather and emergency coms. Boat should have a compass, but if it doesn't not too much to worry about. Assuming you're sailing in reasonable conditions fairly close to shore.
It helps people answer your question if you put a bit more information in your profile, especially location and boat info.
I would check with the Coast Guard for required equipment, as well as your local authorities. Have at least that stuff on board and just for personal satisfaction get a Coast Guard courtesy inspection and earn a sticker.
Apart from required equipment, it all depends on your boat as to what else you'd want to carry.
All equipment needs to be attached to the boat. After a capsize it doesn't help if your bailing bucket foats away or sinks. Maybe a waterproof bag to keep small items. Consider also extra jackets and hats (if not for you, then for guests).
You can check out the RI safe boating info at
Rhode Island Boating Safety Course and Exam - Official Boating License and Boater Safety Course, It has most of the info you would need.
Don't forget a horn, and compass or a portable gps, the bay can go from
sunny to pea-soup fog in less time than you think.
Here is a USCG publication that not only tells you what you need to have on your boat (carriage requirements), it also tells you some of what you need to know. Also, did you know that Rhode Island has Mandatory Boater Education requirements ? Forgive me if you do know this already.....
yes i plan on having a gas motor i was thinking around 2-5 hp it's came with a 3hp but can't get it running. what do you thinking of a electric motor? It would be cheaper. but would it be better than gas. i mean i will be using the motor to go from shore were i launch it out past other boats and than sail and also coming back in and into docks.
I really have too little experience with small engines to comment either way - I don't use an engine at all. This thread discusses it somewhat. I have used rentals (Pearson Ensign) in the bay that use an electric to get away from the dock.
How lively is your sailing? The pictures of the Mistral I looked at had it rigged with a trapeze. You'll need to strap down the tank or the battery, regardless. On the other hand, is paddling a possibility?
i could be with out a motor because i was thinking of having it so i don't have to paddle and going from shore past the break water about 20' away. and entering the harbor and leaving it might be a little hard get in and out.
Related Threads
1.7M posts
173.9K members
Since 1990
