SailNet Community - View Single Post - Need Help Fixing A Wilcox Crittenden Head Toilet
post #7 of Old 05-26-2011
svsirius
Location: Ft. Lauderdale, FL currently CLODs [cruisers living on dirt]
It depends which model you have. One trick I have learned over the years is that sometime you have to prime the pump. Disconnect the fresh water feed coming from the pump to the bowl. Pour some water into that line and slowly lift the pump lever drawing water into the pump body. Once you have done that reconnect to toilet and that should do it.
Jon D
SV Sirius
Moody 47
svsirius is offline
