SailNet Community - View Single Post - Instrument and Panel Back Lighting
post #9 of Old 05-27-2011
mitiempo
mitiempo's Avatar
Chris
I wouldn't wire the panel lighting into the cabin lighting circuit which will probably be on when you are aboard. If the lighting circuit were turned off you would have to get out of the V-berth to go to the panel to turn the V-berth reading light on.
It bothers some and not others. A separate switch makes sense. I wouldn't dedicate a breaker to it. You could install a toggle switch beside the panel for this.
Brian
mitiempo is offline
