SailNet Community - View Single Post - Slightly unorthodox anchoring technique
post #12 of Old 08-05-2006
sailingdog
Originally Posted by solent
You are right, if you notice I said when the boat pulls on it. The pressure is downward. Tie a rope say to a garbage/dustbin lid, throw it over the side, pull it up, you will notice the pressure is not neutral.
If you are relying on water pressure to hold your boat in place, you're a bigger fool than I thought.
The resistance you feel, trying to pull a dustbin lid up, is not water pressure, but resistance due to the shape of the lid and the viscosity of the water. However, water is not as viscous as mud or sand, which provides far more resistance to the anchor moving. You might want to re-read what I've written previously about what the real forces holding your anchor to the bottom really are.
sailingdog is offline
