SailNet Community - View Single Post - Engine mounts
Thread: Engine mounts
post #2 of Old 05-29-2011
sawingknots
you can try tightening them but usually they are too rusty after you will need to realign the engine,use feeler gadges beween the couplings,i think you can also put on new ones by unbolting the coupling then jack up the engine,you my need to unbolt the brackets that the mount studs go through,hard but doable,the muffler can maybe be tightened by using slightly larger screws
sawingknots is offline
