SailNet Community - View Single Post - Honda Generator not triggering charger
post #1 of Old 06-05-2011 Thread Starter
boltnbrew
Hello all,
I have a brand new Honda EU2000i charger that I want to use as a charging generator while on the hook. I filled her up with oil and gas, plugged in the 30A shorepower cord that I had just disconnected from my dockside service and . . . . Nothing.
The "shorepower" indicator on my onboard panel did not light up like it does when connected to shorepower.
I tested the standard 110v outlets on the generator by plugging in a hairdryer. It worked fine. I did not have a way to test the 30A socket.
I've got a Xantrex Freedom Marine 25 charger (130A three stage) and Link 1000 monitor. There was no indication of shore power on the monitor panel. The analog amperage gauge on my panel did not show any incoming charge.
I checked the breaker where my shorepower connection plugs into the boat and it was fine. I unplugged from the generator and back into dockside service and it was fine.
The rated output on the generator is around 16A. Is there a "minimum" current that is required to "trigger" the Xantrex and/or its monitor? Any suggestions? I must be missing something.
boltnbrew is offline
