SailNet Community - View Single Post - Yanmar YM oil pressure alarm failure
post #2 of Old 06-09-2011
SVCarolena
Pearson 303
SVCarolena's Avatar
They way you describe it, it is most likely is a problem in the panel switch. I'd start there with a multimeter before going to the sender. Is is very uncommon for a sender to go bad, particularly on an interment basis like you describe. On the other hand, the panel and switch are exposed to the elements, so there could be corrosion inside.
SVCarolena is offline
