SailNet Community - View Single Post - Looking at a Hunter 27 for first Sailboat
post #7 of Old 06-09-2011
olson34
Lightbulb Lots of Choices
Originally Posted by aeronca View Post
Looking for our first Sailboat. Sailing newbs, interested in something in the 26-29ft range. Will be using for daysailing, weekends and some longer trips. Mostly sailing in the San Juans and maybe some trips up around Vancouver Island, Desolation Sound etc. Figure its a boat to learn on so looking for something under 10k if possible.
Have looked at several boats so far, Catalina 27s, Cal 27, Ericson 27, Santana 27, Oday27, an S2 8.0 and a few others as well. Been all over Craigslist and Yachtworld, etc. Choices are a bit slim here in the Northwest, or I should say boats that don't scare me anyway.
Have found a very clean Hunter 27, I believe a 77 or 78 model. It is actually the first boat we looked at. Has an yanmar 8hp diesel engine, very nice looking sails, very clean inside and out. Anyway was just wondering peoples experience with the Hunter 27 of this vintage. Like I said we are new to sailing and this will be our first boat, so we don't really need anything fancy or capable of bluewater sailing. I figure at this price range we should just find the boat in the best possible shape that meets our needs. But at the same time we really don't want a dog to sail either.
Given your list, as stated, you omit any acknowledgement that all these boat are unequal in sailing ability and original design and construction.
Admittedly, after several decades, present condition is really really important, but, still, they were and are not equal choices.
Speed-wise, under sail, you would put the Hunter 27 and the O'Day well under the others. They also suffered from cut-rate engineering and construction back in the day. OTOH, the S-27 and the Cal 27 would be a lot faster. The Ericson has very good sailing manners, and a far stronger hull-to-deck joint than any other on your list, altho the S2 might come close.
For pure sailing, the Cat 27 would be another good choice, albeit with an upgrade to the later-design rudder From Booth up in BC.
I would also agree with other posters that an outboard on a bracket is awful on a high transom on any boat that big. IIRC, only the E-27 and Sant 27 came with transom cut-outs for a stock outboard, and that makes a big difference. Yes, the old Cat 27 did come with a cutout version, but even back in the 80's it was not a good fit for the modern four-strokes coming into vogue.
BTW, you ought to put the 80's Beneteau First 26 on your list. A couple we know bought one for cruising and it's both fast and comfortable.
Happy shopping,
LB
olson34 is offline
