SailNet Community - View Single Post - How to change your engine mounts
post #1 of Old 06-11-2011 Thread Starter
imsaint007
Camper Nicholson 44
imsaint007's Avatar
A very trick job if you need to work around your engine and no room to jack up the engine and no place to anchor your lifting device ,I had this problem , even the smaller palm jack could not position it to remove and replace the mounts so I had to come out with a contraption to work around and out of the way of the mounts with room to remove and replaced it.
Here is my gadget that consists in pluming pipes and a bottle jack .
Hope some else can use the idea .
Engine Perkins 4236 1.200 lbs
Cheers!
imsaint007 is offline
