SailNet Community - View Single Post - Teak Rub-rail
Thread: Teak Rub-rail
post #5 of Old 06-17-2011
RichH
RichH's Avatar
If you dont seal the rub strake to the hull, water will accumulate between the two and will eventually permeate through the wood and thus turn it 'dark/black' must faster. Also trapped moisture 'behind' the wood will especially cause the coating to begin to 'lift' at the margin of the wood nearest the hull. Very best is to 'encapsulate' the strake with epoxy on the side that touches the hull, then affix to the hull with 'caulk'.
Simple answer: seal it, standard "Life Cauik" that is 'colored' (teak, mahogany, etc.) will work best and will be the 'least obvious'.
RichH is offline
