SailNet Community - View Single Post - chain stopper
Thread: chain stopper
post #4 of Old 06-19-2011
jrd22
Courtney the Dancer
jrd22's Avatar
As long as the chain runs true to the windlass from the stopper and you have the stopper properly mounted (sounds like you do) you should be good to go. I'm not sure I understand your concern about when the anchor enters the roller? As long as you have enough length between the stopper and the end of the shank when it's pulled in tight there shouldn't be a problem. The chain will make it's "bend" at the stopper instead of at the windlass, but I've always figured that was good for the windlass. Make sure your backing plate is as large as physically possible under the mounting location.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
