SailNet Community - View Single Post - Slightly unorthodox anchoring technique
post #17 of Old 08-10-2006
Newport41
Thanks solent for retracting your stupid statment and adding an even more idiotic one. The pressure is in fact neutral. When you pull up you are feeling resistance. If you were to pull down it would be the same if the lid had neutral bouyancy. Can I put foreward a motion that people should have to pass a grade 8 physics test before they can post? Was it you that asked about the fan on the sailboat? Cause that wasn't even as stupid as this. Thanks for coming out.
Newport41 is offline
