SailNet Community - View Single Post - Where do people secure their battery banks?
post #9 of Old 06-23-2011
Jeff_H
Moderator
Jeff_H's Avatar
The broad generalities with Lead acid batteries is that you want the following;
-Located as near to the engine as you can get them:
-Located near the center of buouyancy in the boat and out of the ends of the boat and as close to the centerline as you can conveniently get them:
-They should be in a compartment which is vented but not to the engine compartment or bilge:
-They should be in a cool location which is not subject to flooding:
-They should be in a location where they are easy to inspect (i.e. good light) and refill with water (i.e. no intrutions over the battery.
-They should have a pan to catch any water and acid that spills during filling or heeling.
-The batteries should be lashed down so that they can't rock around or fall out.
Fans have tiny draw compared to starting the engine, or charging the batteries after a start. Keep the batteries near the engine....
Jeff_H is offline
