Originally Posted by Dave A
This is my 2nd P-35 and up until now I really never thought about this potential problem. The cockpit drains, the large 2" ones, exit below the water line and if you take off the connecting hoses the water is probably an inch below the top of the fiberglass tube, with the boat healed it would come in at a good rate. I had one leaking at the fitting last summer, when I replaced the hose the water was right there. Has anyone out there thought about putting valves on these.
Hi there, ALWAYS have valves on an underwater exit, even when 0.5"only. Even when the exits are slightly above the waterline consider valves.
Brgs John Slot / Tilikum P365
