SailNet Community - View Single Post - Stuck floor hatch PSC 34
post #3 of Old 06-27-2011
RainDog
Not Finished Yet
RainDog's Avatar
I had the same problem and decided the problem was they were two close to each other. I forced a shim between the two boards to push them away from each other. Then used a lever to pull one up. After I had them up a cleaned all the joints really well and now they come up pretty easy. If you have a dehumidifier or AC, run it for a week before you try to reduce the swelling of the wood. This will make your life much easier.
RainDog is offline
