SailNet Community - View Single Post - shaft\coupling tolerance
post #6 of Old 06-30-2011
Maine Sail
Maine Sail's Avatar
It should be a light press fit if this is a straight coupling. It should NOT just slide over the shaft easily.. This fit is usually fitted by hand by the machine shop. I would suggest using a "split" coupling then the fit is not quite as critical but it should still be pretty snug on the shaft.
______
-Maine Sail / CS-36T
Maine Sail is offline
