Old 06-30-2011
Cruisingdad's Avatar
Cruisingdad Cruisingdad is offline
Best Looking MALE Mod
Depending on how hard chined the boat is, you will love it or hate it. Ours is a 'flatter' bottom than many boats, and almost all Catalinas except the new 445 (Which I really like). THe pros are that the boat should perform a lot better than the typical round bottom boat. We also found our boat to be more sure footed and sail flatter. Alltogether she is comfortable at sea. THe bad is if it is too hard chined, for a sailboat especially, when you get into choppy water or a large sea (for us about 10'), when she jumps off the waves, it sounds like a bass drum below. There are some boats with hard chimes that are so loud it has run off the owners. You can PM for the mfg I will not put it openly.
I am not familiar with the 409. Have not seen her or sailed her. But I am curious how you build a 40' boat at $200k? Wow. The C400's new will run you well into the 200s with your final bill likely into the low 3's after you get everything you want on them. At least that is what a dealer told me.
I would at least look at a Bene 40 and a C400 for comparrison. I like the Sabres too. But I don't think you will touch any of them in the 200k range... not realistically.
Hope that helps. Good luck with the purchase.
Brian
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Follow me on Facebook:
