SailNet Community - View Single Post - Cheese - Freeze it??
post #8 of Old 08-12-2006
sailingdog
Generally, the harder and drier cheeses will last longer than the softer and moister cheeses. Dipping the cheeses in wax or storing them in oil will further prolong their shelf-life.
I generally don't recommend freezing cheeses for a couple of reasons. First, it changes the texture and the taste of the cheese a bit. Second, freezers require energy, which is something that is a scarce commodity on a boat—I'd prefer to use the electricity for something else, and use a non-refrigeration method of cheese preservation.
If you're sailing in more temperate waters, the bilge of your boat will often be cool enough to help preserve most cheese. This doesn't work in the tropics, where the bilge and the water can be above normal room temps.
sailingdog is offline
