SailNet Community - View Single Post - shaft\coupling tolerance
post #8 of Old 06-30-2011
centaursailor
Senior in age only!!!
centaursailor's Avatar
A properly sized taper lock coupling should not present any difficulties . The taper lock bore is designed to tighten on the shaft as the taper is driven into the coupling via grub screws. Some systems also use a key to deliver the drive but that must be machined into the shaft.
Safe sailing
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
centaursailor is offline
