SailNet Community - View Single Post - Stuck floor hatch PSC 34
post #10 of Old 07-01-2011
okapi3
I have had and solved this problem. It is due to humidity swelling the boards. For a while, I removed the stuck boards using a sail tie, in a loop, with a carabiner attached. I put the carabiner on the finger pull of the floor board and the sail tie around my hips and then by squatting and doing a quick leg press, popped the board out.
Finally, I used a hand plane and planed the edges down and then sealed them with epoxy and the boards no longer stick.
Paul Cooper
PSC31 #9 "Wayfarer"
Chesapeake
The secret to sailing is good judgment. Good judgment comes from experience. Experience comes from bad judgment.
okapi3 is offline
