SailNet Community - View Single Post - halyards rope vs wire
post #2 of Old 07-05-2011
sailjunkie
Mirage 29
sailjunkie's Avatar
When we first started sailing, all of the boats in our co-op had halyards that were a combination of wire/rope. The wire lasted longer, but when it started to go, there were ends everywhere, increasing the risk of cutting hands. Plus, replacing wire is more expensive than rope.
However, you should check the sheaves at the mast head before making your decision. Some sheaves are meant only for wire halyards, and they should be replaced if you are going to switched to rope halyards. You may be able to get away with using your existing sheaves, but I would check with an expert.
Our co-op switched to all rope halyards quite a few years ago, and have been happy ever since. Our own boat has all rope halyards.
Mark
S/V Avatar
Mirage 29'
Port Moody, BC
It's not my fault they named a movie after our boat
sailjunkie is offline
