SailNet Community - View Single Post - Yanmar 4JH-2E using coolant
post #1 of Old 07-12-2011 Thread Starter
Tim R.
Tim R.'s Avatar
Here is what I know:
- Engine runs very well with ample power at all rpms
- I have to top off the overflow tank after every 4 hours of motoring
- No overheating(yet)
- No coolant in oil(crack in block)
- No pressure in heat exchanger when running the engine with the cap removed(bad head gasket)
- No apparent leaks under the engine
What is left are the following:
- Hot water heater leak
- Heat Exchanger leak
- Exhaust riser leak
- hidden leak into bilge
- Something I am missing?
Any of these should have coolant in the bilge, hot water system or the exhaust. Does anyone know of a way to test for coolant(trace amounts) in water?
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
