SailNet Community - View Single Post - Yanmar 4JH-2E using coolant
post #4 of Old 07-12-2011
jrd22
Courtney the Dancer
jrd22's Avatar
I think I would try to isolate where the leak is by disconnecting the lines to the hot water heater. If you are still using coolant then it's got to be engine. You said that there was no pressure in the overflow with the cap off while running but wouldn't it be more apparent if you left the cap on so the pressure built up? There is a way to check if exhaust gases are present in the coolant, an automotive parts store should have it.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
