SailNet Community - View Single Post - ST 60 instrumentation mounting
post #10 of Old 07-15-2011
puddinlegs
Honestly, I've never seen a boat with instruments (other than an autopilot with a plastic cover... yes, it was a PITA to get to much of the time too!) mounted where you're planning to have them done. I can't imagine having to crane my head or neck around unless you're mounting port and starboard repeaters, and even then, you can't see them downwind if you're driving, not to mention the cost. And this is all before you have other people banging into them, in the way, etc. On the other hand, I've seen a lot of boats use an instrument pod/box/etc... mounted forward of the companionway or built into a spray hood. Have you considered mast mounted instruments? They're about the easiest to see of the lot unless you have a very old dodger that needs replacing as well.
puddinlegs is offline
