SailNet Community - View Single Post - Examining for potential swing-keel failure
post #3 of Old 07-18-2011
CalebD
Tartan 27' owner
CalebD's Avatar
Can you remove the pin (fulcrum) while the boat is on the trailer? If so you can inspect it.
To inspect the cable it would be easiest if the boat could be raised in a TravelLift slings or a crane and then lower the board for inspection of cable attachment point.
Can you look up the center board trunk using small pieces of mirror and a flashlight while still on the trailer?
You should be able to inspect the upper portions of the cable for 'meat hooks' somewhere inside the boat too.
Everybody has one:
CalebD is online now
