SailNet Community - View Single Post - Wanna be sailor
Thread: Wanna be sailor
post #3 of Old 07-20-2011
CalebD
Tartan 27' owner
CalebD's Avatar
Having a boat that you can keep on a trailer will save you thousands of dollars in marina and storage expenses. It will also severely limit your choice of potential boats.
Without knowing what body of water or where you intend to use your boat also makes it difficult to suggest a particular model.
You can have a trailer made for nearly any boat but launching a fin or full keeled boat at most launching ramps will likely be difficult if not impossible.
That said, you might start out by looking at the MacGregor line of boats. The MacGregor models <= 25' are routinely trailered but are a bit older. Of the 26' MacGregor boats I would only suggest looking at the 'S' model (not the 'X', 'M' or 'D' models) as it is a better sailboat then the others, has room to sleep 6 but is not really suited for heavy conditions you might find out on an ocean. Hunter makes a 26' that is also a water ballasted boat.
Where you intend to use it is an important part of the calculus.
Everybody has one:
CalebD is online now
