SailNet Community - View Single Post - Questions about new purchase
post #5 of Old 07-20-2011
0verdrive
Originally Posted by markchicago View Post
The water is in the hull and exits from a plug in the transom. From what I can gather is this is an auto bailer set up which is missing obviously. Not sure about foam but will check. Solution I believe for now is to plug the port and reasses over the winter. The cockpit isnt so big that I need a bailer in the summer at least. It seemed no way this could be the design but the plug in the transom gave me pause since I didnt see how any water could get in otherwise except at the mast if at all. Thanks
My Laser II has a hull drain in the transom that looks like this:
If this is what you're referring to, it should also have a plug that looks like this:
If you don't have the plug, you could probably replace the plug and housing somewhere like here
Dean Wilson
Melges M20 - The Can-Do Girl
Lake Perry, KS
0verdrive is offline
