SailNet Community - View Single Post - Yanmar 3YM20 Oil Pressure Alarm with B Engine Panel
post #1 of Old 07-22-2011 Thread Starter
CapitainMike
CapitainMike's Avatar
Question Yanmar 3YM20 Oil Pressure Alarm with B Engine Panel
I have 2 Batteries one Starter one House.The problem is that any switch on the panel on the the house bank when switched on causes the oil pressure alarm to activate on the engine panel.
The switches for everything on the House bank main switch panel have all been re - soldered and duff diodes have been replaced.
With all House switches off the engine starts normally with the oil alarm on then turns off when the engine fires as it should.
The engine and its ancillaries has only done 197 hours since new.
There is more I could tell you but I don't want to confuse the issue with things that might be not be relevant.
So please ask me your questions.
Your suggestions will be gratefully received.
Capitain Mike
Mediterranean Sea
Cobra 850
1978
8.68m
"Money won't buy you happiness but it will allow you to buy a yacht big enough to pull up along side it"
"Please God be kind to me your sea is so wide and my boat is so small"
CapitainMike is offline
