SailNet Community - View Single Post - Change Battery Selector While Engine Running?
post #20 of Old 07-26-2011 Thread Starter
maccauley123
SailAway
maccauley123's Avatar
I appreciate all the input and my plan is set.
1. At some point I will install an Echo or similar regulator and change up my wiring configuration. I completely rewired the boat a couple of years ago adding new wiring, fuses and a breaker panel etc and took great care to try and do it right. This never came up so will fix that.
2. In the meantime I will just adjust how I function. I have an analog voltmeter which was starting to show roughly 12.2 values. I thought it was supposed to be up near 13 but did not pay it much mind. Never again. I am on a river and have a roughly 30 minute motor to get to the end of the channel. Going down the river will start/run off battery 1 and going up the river will start/run off battery 2. This way both batteries will get full attention for at least 30 minutes per trip. Until I get the regulator this is probably the best I can do.
I will also pay more attention to the batteries in the off season and bring them in to get tested. The last thing I want is to not be able to start my engine when I have to get back to my mooring against an outgoing tide. I have SeaTow but would rather not have to call them. I am also planning to get an electric trolling motor and battery for my dinghy which will serve as a nice backup if needed.
You will regret the things you did not do, more than the things you did.
Get out there!
Saco Bay, Maine
2001 Beneteau Oceanis 361
maccauley123 is offline
