SailNet Community - View Single Post - Anchor light
Thread: Anchor light
post #14 of Old 07-27-2011 Thread Starter
junkrig
Both ends are pointy.
junkrig's Avatar
Originally Posted by noelex77 View Post
snip...
...My LED Owl is much brighter than the masthead anchor light fitted to most boats (and I have 2) It will even illuminate boats anchored close to me.
This got me curious. My Missouri handbook says : "a white light visible from" blahblah...
You're using two. If I could use two I wouldn't have to worry about anything on the masthead where I am. So I dug out the final authority, the ColRegs. Colregs says (fresh water)
(a) a vessel at anchor shall exhibit where it can best be seen
(i) in the fore part, an all-round white light or one ball
(ii) at or near the stern and at a lower level than the light prescribed in subparagrah (i) (emphasis added), an all-round white light
(b) a vessel of less than 50 meters in length may exhibit an all-round white light where it can best be seen instead of the lights prescribed in paragraph (a) of this rule
(c) A vessel at anchor may, and a vessel of 100 meters or more in length shall, also use the available working or equivalent lights to illuminate her decks.
The illustration attached shows the aft "all-round" light clearly mounted behind, and partly obscured by, the bridge.
So my original post was based on an error; I thought that I could only have one anchor light (from my Missouri book) and knew that it could not be seen over 360* due to obstruction from my fat mast.
All very interesting.
S/V Seablossom Nor'Sea 27 with modern junk rig.
Just because I like it.
junkrig is offline
