SailNet Community - View Single Post - Anchor light
Thread: Anchor light
post #16 of Old 07-27-2011 Thread Starter
junkrig
Both ends are pointy.
junkrig's Avatar
Originally Posted by junkrig View Post
It is difficult to tell for sure from the text of the ColRegs whether it would be permissible to have green / red lights at the masthead on a power boat, above your steaming lights, but in 100% of the illustrations the white steaming (forward visible) is above the red / green sidelights. That would imply that you would have to turn off your masthead light and use deck or cabin sidelights to run under power.
Length is not a factor in these illustrations.
However, he said, correcting himself:
the point at which the 12 meter breakpoint does come into play is that, for boats under 12 meters, it is acceptable under power to use sidelights plus one 360* white light, whereas over 12 meters the requirement is for a 225* white masthead light plus a white 67.5* sternlight. Boats over 12 meters seem not uncommon on SN.
S/V Seablossom Nor'Sea 27 with modern junk rig.
Just because I like it.
junkrig is offline
