Boat Cushions and Foam
I''ve spent the last few weeks on the same mission re exterior cushions. Closed cell foam (relatively hard and dense and floats, no water absorption) and flow through ( no water absorption, softer, doesn''t float) foam seem to be the two most practical choices. Both can be obtained from Sailrite (www.sailrite.com) but are pretty pricey. I happened to find a foam source in Philadelphia that sells flow through. Choices for interior foam are multiple since water absorption is not a major concern. Any foam will do as long as it''s comfortable for you.
