SailNet Community - View Single Post - Correction for Leeway - Coastal Navigation Question
post #11 of Old 07-30-2011
RichH
RichH's Avatar
Originally Posted by kwindancer View Post
Hello All,
Hope you can answer and explain the answer to this question:
Let's say my point of departure is at point A and destination is to point B.
The track (Course to Make Good) from A to B is 145 degrees magnetic.
The winds are west at 22 knots when I depart point A at 1530. Let's say the leeway is 4 degrees and the boat speed is 6 knots. What course, corrected for leeway, should I steer from point A to point B?
Thanks so much.
The 'solution' lies within your question.
A—B = 145M
leeway = 4
therefore steer 145 + 4 = 149 to arrive at B
rigorous solution:
SIN 4 = 0.06975
1 mile = 6080 ft.
1 mile X SIN 4 = 6080 X 0.06975 = 424 FEET
therefore aim 424 FEET (per nautical mile per total distance travelled .... or add 4) to the 'right' (windward side) of your course and you will be 'ded-on' at your arrival: 145 + 4 = 149M
If the wind would be from the east and causing the same value of leeway, then subtract 4; 145 - 4 = 141M
RichH is offline
