SailNet Community - View Single Post - Advice, please on crimping wire connections...
Old 08-18-2006
FrankLanger FrankLanger is offline
FrankLanger is on a distinguished road
I have to make some wire connections this weekend on my boat, and think I know what I'm doing, but would appreciate confirmation or correction. The wires are to the bilge pump, in an inside quarterberth locker. I have bought the right sleeve (blue) for the size 14 wires, and have a crimping tool. I am planning to cut about 3/8" of the insulation off the wire ends then twist a bit to avoid a stray thread of wire, then insert as far as it will go into the sleeve, then squeeze the heck out of it with the crimping tool, then test by pulling firmly on the wire to see if it will hold.
I don't have a soldering iron, and have heard mixed opinions on whether soldering is good on a boat (better connection, but more brittle/prone to breaking with vibration, acid in solder flux not good, etc.).
In one case, I have to add two wires to one end of the sleeve, and only one wire to the other end of the sleeve--any advice? Do I use a larger sleeve to accommodate the two wires and just squeeze harder for the single wire on the other end, or try to force the two wires into the smaller sleeve?
Thanks for any advice--I do need my bilge pump to work.
Frank.
