Dave6330— please don't hijack someone else's thread...if you've got a un-related question, please start a new thread.
A lot of times you can also get longer slugs, to replace the ones you're currently using. A longer slug or slide is far less likely to twist in the track and get bound up.
McLube Sailkote or Boeshield T9 are both good lubricants for the sail track, as are some of the silicone-based lubricant.
The checking for burrs is a very good idea, as is cleaning and lubing the track.
