The other real problem with soldering is that the solder moves along the wire via capilliary action and can cause the wire to become rigid...so you're defeating the purpose of getting good marine-grade wire in the first place. Where the solder creeps along the wire, it will fatigue and break much more readily than unsoldered wire of the same size and type. Also, the real problem is that the heat that can occur in a boat's electrical system can cause the solder to melt and then the wire may fall free and short out on something more dangerous...
