SailNet Community - View Single Post - Broken piece of starter in Yanmar 3GMD engine
post #1 of Old 08-06-2011 Thread Starter
logisoft
Hi,
I've got a treasured rebuilt Yanmar 3GMD that I installed myself 6 years ago. The purr of that engine means a lot to me.
I'm also, due to circumstances, cheap. I installed a new chinese starter last season and the housing of the starter gear broke inside the engine. I took it off and fished a large broken piece from the place where the starter gear meets the flywheel. I fitted it back on the starter and discovered a smaller piece (about 1/2 inch flat square) missing. Where did it go? How hard will it be to retrieve? What bad things could happen from this piece being somewhere inside near the flywheel? I replaced the starter and the engine starts and runs like it used to. I think I do hear a little metallic "tinkling" sound every once in a while.
My nightmare is that the little piece of metal will get into the flywheel teeth and be driven through the engine casing. Is that rational?
Thanks for your advice.
Dan
logisoft is offline
