SailNet Community - View Single Post - Broken piece of starter in Yanmar 3GMD engine
post #3 of Old 08-06-2011
bljones
bljones's Avatar
Are you cheap, or frugal? (Answer is at the bottom of the post)
You can pull the motor, tear it down and remove the missing fragment now,
(Total cost- some time and a couple of gaskets. Total inconvenience- moderate)
Or you can ignore it and hope for the best. It may NEVER be a problem. Or, it may decide to jump up and jam the flywheel and do a job on the wheel, the case, the crank and the bearings, usually when underway, off a lee shore.
(Total cost- LOTS. Total inconvenience- extreme.)
The question you have to ask yourself is,
Do you feel lucky, punk?
BTW, the difference between cheap and frugal- a cheap sailor will ignore the problem and hope it isn't really a problem. the frugal sailor will fix it now, while the fix is still cheap, and learn from the experience. Cheap sailors always spend more in the long run than frugal sailors.
It's 5 o'clock somewhere:
bljones is offline
