SailNet Community - View Single Post - bottom paint hard or ablative
post #5 of Old 08-07-2011
alanr77
In my opinion, the only real problem with hard paints is that they leave you with a wonderful leftover to sand, scrape and deal with once the copper has leached out. The ablative paints wear away and leave you with less to deal with. On power boats, I have used hard bottom paints in both fresh and salt water with few issues. The speed at which the boat travels seems to favor the hard paint as it does not wear away as fast. However, on a sailboat I have rarely gained enough speed to wear away the ablative paint at a rate that made it impractical. Another thing to think about is how you will be scrubbing the bottom. In Savannah Ga, with the extremely warm water and high growth rate, I have to scrub the bottom almost weekly. This quickly wears away my bottom paint (ablative) to the point that I can see the base coat by the end of the season. Don't know if this helped you in any way but just a few things to think about. AR
SV Salinity
alanr77 is offline
