SailNet Community - View Single Post - Compression Post?
post #4 of Old 08-20-2006
sailingdog
If I were you, I would install the compression post, but add a plate of some sort on both the top and bottom of the post to spread the load out. Concentrating that kind of load is generally a really bad idea, and may cause worse problems than you already have.
Stainless steel is probably the easiest to work with, and far better than Aluminum, which has much more trouble with metal fatigue. Carbon fibre is probably the most difficult to work with and expensive of the materials you've listed. Wood is also a possibility, but my preference would be SS, Al, Carbon Fibre, and then wood in order of preference.
sailingdog is offline
