SailNet Community - View Single Post - Cal 21 Keel
Thread: Cal 21 Keel
post #39 of Old 08-08-2011 Thread Starter
sailnova's Avatar
It is 3/16in so it is a bit small. In the keel re-build process we ended up putting some filler that was then drilled out over the locking hole...From a thread on the cal 21 site I read someone using a 1/4in brass. Apparently the original is 1/2in. It's easier to make the hole in the trunk bigger rather than smaller which we plan on doing. Rippy, is the pin you have 1/2in?
sailnova is offline
