SailNet Community - View Single Post - "Drop-in" replacement for Yanmar 2GM
post #3 of Old 08-09-2011
CapitainMike
CapitainMike's Avatar
Originally Posted by scraph View Post
My boat has the original Yanmar 2GM (1981 model). I was wondering if Yanmar has a new model with higher power output that was designed to drop in place on 2GM mount/mount locations?
The 2GM doesn't even have enough power to push me at hull speed and I would like to do that as well as install a second house-bank alternator.
Thanks for any ideas.
The 3ym20 drops straight in it uses two of the 4 existing flexible mounting feet holes and you have to re drill the engine bed for the other set of feet.
If you go on the Yanmar site you can download the technical drawings.
I would also suggest that you move the primary fuel filter to where you can access it easily. Mine is on the port front engine bed. You must also take into account that the main service side is now on the starboard side of the engine. so make sure you can access the oil filter easily. I think the 3YM30 is similar but Please do check
Capitain Mike
Mediterranean Sea
Cobra 850
1978
8.68m
"Money won't buy you happiness but it will allow you to buy a yacht big enough to pull up along side it"
"Please God be kind to me your sea is so wide and my boat is so small"
CapitainMike is offline
