SailNet Community - View Single Post - Wouldn't heave to in 25 knots of wind.
post #1 of Old 08-10-2011 Thread Starter
MarkSF
The other weekend winds were increasing so I wanted to heave-to in order to reef the main. They were gusting about 25 knots.
So I simply let the boat tack without tacking the jib - coming through the wind slowly then letting the jib fill progressively. But rather than heaving-to nicely, the bow began to spin around so that the jib was totally taken aback. At this point the angle of heel began to get worrying so we cast loose the jib sheet.
Reefing was done then sailing on the jib, close hauled, with the main sheeted out so luffing slightly. This seemed to work fine, but it wouldn't work single-handed, at least not without an auto-pilot!
I really want to get this boat to heave-to. What did I do wrong?
This boat has a large fore-triangle, so the jib is pretty large. I wonder if this is the problem, that the main can't balance out the force from the jib. I had the jib furled to about 100% at the time. Maybe it should be furled smaller before heaving to? I also wonder if I should have had the main sheeted in more - it was sheeted almost fully out.
Any advice would be helpful and will be tried out this weekend!
MarkSF is offline
