SailNet Community - View Single Post - steamy perkins 4108
post #2 of Old 08-10-2011
PorFin
Seņor Member
PorFin's Avatar
Originally Posted by philipio View Post
hello everybody im new to this site i don't even know if im on the right page, my name is phil im from dublin ireland, i have a 25 ft fishing boat with an perkins 4108 inboard diesel engine, small prob with a very steamy exhaust has anybody got any ideas on what it could be, im not into the mechanical end of things myself, no a bit here and there, any ideas or sollutions would be of help , thanks folks,
Hi, Phil from Dublin!
I'm going to go out on a limb here and assume that you've got a fresh-water cooled 4.108M (i.e., it's got a heat exchanger or h/x). The older 4.108's had the h/w on the front of the engine, while the "New 4.108" have the Bowman PE that is incorporated with the exhaust manifold on the side of the engine.
I'm not a diesel guru, so take this as friendly guessing. Short of a great stroke of luck, there's no way to diagnose this with certainty based on the initial symptom of steam in the exhaust. You've got some troubleshooting ahead of you -- time to break out the reference books and dig in.
First thing to check is to see how much coolant you're losing -- if it's none, then your freshwater cooling system is likely not compromised and you can forget about the first two issues below.
Steam in the exhaust could mean several potential issues:
- Failing head gasket.
- Cracked cylinder head.
- Heat exchanger issues.
- Exhaust mixing elbow issues.
Something you may try early on is to retorque the cylinder head per the maitenance manual. If you haven't done it in a while, it's probably due.
Hope you figure it out, and that it winds up being a minor fix.
PorFin is offline
