SailNet Community - View Single Post - New Islander 28 Owner needs help on floor replacement
post #7 of Old 08-14-2011
ilikerust
1968 Pearson Wanderer 30
ilikerust's Avatar
The plywood sole of my 1968 Pearson Wanderer 30 was rotten in places and overall pretty well thrashed.
So a few months ago, I tore it out.
I used a reciprocating saw (a/k/a "Sawzall" or "saber saw") to take it out in chunks. It had been held down with a thick fiberglass and resin tab all the way around the perimeter, and bedded in a thick resin bed.
So after I tore out the floor, I was left with that thick tab all the way around the perimeter. I used a chisel to remove most of it:
Then I used an angle grinder with coarse sandpaper to grind down what was left:
- Bill T.
- Richmond, VA
"Twenty years from now you will be more disappointed by the things you didn't do, than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
- Mark Twain
ilikerust is offline
