SailNet Community - View Single Post - New Islander 28 Owner needs help on floor replacement
post #10 of Old 08-14-2011
ilikerust
1968 Pearson Wanderer 30
ilikerust's Avatar
I am not going to use the standard "teak and holly" plywood for the new sole. Instead, I am going to make a varnished plank floor.
I'm working on giving the cabin more of an old-fashioned, classic wooden boat feel. I've been working on a few interior woodworking projects along those lines, including replacing a non-structural interior bulkhead with a frame and raised panel assembly.
Check out this cabin sole:
That's pretty much the look I'm going for.
That sole is simply varnished planks of solid wood, butted together. I will use Southern Yellow Pine, ripped into about 4-1/2" wide planks, resawed and thicknessed to 7/8". I will oil and varnish all surfaces, then screw them down to the new floor timbers. I will countersink the screws and plug the holes with black walnut plugs for a nice contrast.
- Bill T.
- Richmond, VA
"Twenty years from now you will be more disappointed by the things you didn't do, than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
- Mark Twain
ilikerust is offline
