If you are really interested in reading about crimped electrical connections, you might want to read the article
here.
I don't know of any tests between crimped and soldered connections, in a marine environment, but soldered connection have a track record of a greater rate of failure than crimped connections, and in a marine environment, you really should be using only marine-grade tinned wire, as you can see from the article I mention above.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
