SailNet Community - View Single Post - Soldering Radio Antenna Cable Connections.
post #5 of Old 08-16-2011
kd3pc
kd3pc's Avatar
sharp knife, directions and dimensions (if you have not done this before), pliers to hold hot connector, strippers, solder and the like, Be careful to not nick the center conductor as it will cause it to eventually break and cause an open connection.
Remember to put the ring on prior to the connector
kd3pc is offline
