SailNet Community - View Single Post - Blower needed for inboard diesel?
post #12 of Old 08-17-2011
Donna_F
The most female moderator
Donna_F's Avatar
Dock
Originally Posted by JimMcGee View Post
Definitely worth doing, and I've ben told if you have the sticker on your mast the Coast Guard will bypass you for on-water inspections. Not sure if this is true...
Jim
Not true. It only says that at the time that you had the courtesy inspection done, you had all of the required legal equipment. At the very least it tells LE that you were informed of the requirements.
There's nothing stopping you from removing any of the safety equipment once we leave your boat, which is why a boater should not count on not being boarded.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
