SailNet Community - View Single Post - Boat Survey recommended for $4000 boat?
post #13 of Old 08-19-2011
canadianseamonkey
Caribbean Surveyor
canadianseamonkey's Avatar
Originally Posted by rundugrun View Post
Thanks so much for the advice... The SJ21 does have known issues with the deck (water damage) and keel. I found an accredited marine surveyor (SAM) who is only about 75 minutes from Indianapolis and therefore much more reasonable in price. I've decided to go that route as I don't want to be stuck with a major hidden problem. Although $3500 - 4000 isn't much for a sail boat, it means a bit to me, so the $300 or so spent on the surveyor makes sense for peace of mind.
Thanks Again!
Doug
Going rate to survey a boat that size with travel is about $500, so if he's doing it for $300 you are getting a very good deal. I just hope he does a good survey for you. Sometimes you get what you pay for. He should be there for at least a few hours and your report should be very detailed...especially if he's accredited through SAMS. Good luck.
canadianseamonkey is offline
